wheelbender6
I love this thread. I recently finished my banana seat bike (Sears Spyder replica) build. I may have to add a hub motor.
E-HP said:Turbotd04 said:I was surprised how hard it was to bend back so there is still quite a bit of strength there I recon and now I haven't got the brake pressure on it it should be ok but if not I can just get a new one. The bend is to far up to be able to cut it and still make the adjustment holes, we will see how it goes but if I start feeling flex its not the end of the world if I need to get a new one.
So that was a lot of force from the brake mount. If you're at all concerned about the frame, you could get a short piece of angle iron (3 inches) to put between the seat stay and bracket to spread the force and resist bending.
wheelbender6 said:I love this thread. I recently finished my banana seat bike (Sears Spyder replica) build. I may have to add a hub motor.
Turbotd04 said:E-HP said:Turbotd04 said:I was surprised how hard it was to bend back so there is still quite a bit of strength there I recon and now I haven't got the brake pressure on it it should be ok but if not I can just get a new one. The bend is to far up to be able to cut it and still make the adjustment holes, we will see how it goes but if I start feeling flex its not the end of the world if I need to get a new one.
Could you explain this a little more? Just trying to work out where you mean, the disc brake mount is a lot more solid than the cheap one I was using before but would like to strengthen then frame as much as possible as well
thundercamel said:I didn't realize that bottom bracket was so low!
