DasDouble said:
Hey guys I am new to this so I wanted to ask some questions to get some know-how about ff. I have a QS V3 motor and also have ordered now 10ml ferrofluid 1110 from a german guy from this forum. He said it will reduce the heat about 40%. I have talked about this with some experienced guys in this and they have told me that it is unrealistic that 10 gram of liquit can cover 40% produced heat of a 45.000 gram heavy bike + 70.000 gram heavy rider.
Could you please explain me how the ff works / why it works?
FF effectively bridges the gap between the heat producing elements (windings) and the heat removing elements (Hub shell/covers). This dramatically increases ability to remove heat. 40% reduction in temperature is absolutely possible. What's more amazing as you could achieve that difference with only using half of your 10ml tube. This has been proven empirically and via experience of many, many people now running FF. The silent majority in this case are those that no longer have heat issues.
Offroader - you have invested more time thinking and writing about this topic than it deserves - buy some FF, install it and see for yourself the difference. It is *very* easy to remove, certainly compared to conventional oil cooling and takes mere moments to do compared with many of the other elaborate methods you have spent lots of time contemplating. The science is already done, see the thread title - definitive testing has been completed and it proved, definitively, that FF is an excellent solution.
Independently of the FF advancement, Sketch has come up with an excellent solution for the other side of the equation and has also definitively proven his hubsink solution dramatically improves cooling ability. If anybody running good quality FF and hubsinks mounted correctly still has heat issues then their controller is incorrectly configured or they are running a motor very inadequate for their requirements. a QS 50mm v3 with FF and hubsinks is capable of serious performance for extended periods of time, far, far in excess of what I could personally use despite being young fit and not afraid of breaking rules. At this end of the spectrum I do not believe there's really a problem left to solve, unless perhaps you're morbidly obese.
