dumbass
I welcome your thoughts, opinions and most importantly any information and/or help you can provide me.
My wife and I each have 2 ebikes. a 7 year Wallie World bike with 360w Cyclone motor kits new Ezip. She is only interested in short forest preserve rides using the car to transport the bikes. But I like to do my own thing or venture off with a friend and ride 20+ miles. I live in a rural area surrounded by great forest preserve trails and I prefer to start out at home and head for the trails. I want to increase the top speed on my Ezip (without changing the voltage or losing current hill climbing power). This is my idea to increase the top speed. Please note I am already running 24v 20ah lipo4 batteries and ordered a second set of these batteries to add to my capacity.
1) Install a Nuvinci hub that I already own
2) Add a second stock Ezip 450w 24v motors (The motors will not run simultaneously).
3) Mount both motors on the right side and drive them through the Nuvinci hub
4) Install a motor selector switch (same switch used to select the battery) on the handle bar or use the TAG/PAS push button through a relay to select which motor is allowed to run
5) Install a freewheel on the crank sprocket
With this setup I can start out with the low geared motor if I want to shift to the high geared motor I let off the throttle, press the selector switch and hit the throttle again. This setup should allow me to have great hill climbing power for fun on the trails plus added speed capability for roadway riding.
Here's the help I need...
!) Does anyone know where I can get a relay so I can use the TAG/PAS push button through a relay?
2) I have heard about a 2 motor mounting plate for the Ezip. This would be easier then making one. Does anyone have info where to get this plate?
