unicyclewheelie
- Joined
- Apr 21, 2022
- Messages
- 1
This bike is a Basic PAS, I am wanting to convert it to a throttle only, because 1st power level you don't feel any help from the motor, maybe 10-20% and 2nd is a good boost of power maybe 60-80% and 3rd is 100%
Also you cant peddle fast enough to keep up with the speed at level 3 power. So your just spinning your feet slowly to keep the motor/bike going.
Specs:
Motor 180 Watt 24v
Battery 24v 5.2AH
The bottom of the battery holder is really thick and has three cables coming out of the bottom
2 small( handlebars controller, and cadence sensor), 1 thicker(to the motor)
Maybe where the controller is hidden inside?
Rated voltage 24v
Rated current 8A
Low voltage protection 20v
Maximum current 15A
The brake levers each have 2 pin connectors to cut motor power when used. I unplugged them both and the PAS still works.
The power selector, battery status and on/off button has a 5 pin connector.
The PAS is a constant power. 3 Power Levels (small assist, medium assist, large assist)
How would i go about making this a throttle only bike?
Would I need another controller?
Would it work with PAS removed?
This is my first ebike build/mod
Specs:
Motor 180 Watt 24v
Battery 24v 5.2AH
Rated voltage 24v
Rated current 8A
Maximum current 15A
