ebikedelight
- Joined
- Dec 25, 2014
- Messages
- 307
After spending the last few weeks comparing price/ benefits/ of using either hi amp lipo or hi amp lifepo4 , I feel that the lifepo4 still is the best all around setup for ebikes when purchasing pre-made packs ecpsecially if a person needs a charger and BMS unit as part of the package .
lowest price for 48 volt style setup on ebike / 48 volt controller _
LIPO
multistar lipo - 6s pack - 10 ah - using 4 packs to get 12s -20 ah - $428 shipped for 4 packs ...total weight of around 11 lbs . This gets you 50.4 volts at the max of 4.2 volt per cell, which many claim will reduce the packs lifecycle to only a few hundred cycles before it needs to be replaced. This price does not include a BMS system or a specialized safe charger .
LIFEPO4
lifepo4 - 16 cell pack - 48 volt - 20 ah battery, charging to max of 3.6 volts per cell for 57.6 volts max charge...weight about 20 lbs ... for $390 shipped , which includes a BMS unit and a safe charger .
For a simliar price the lifepo4 offers :
2. higher overall voltage which should result in better speed/ power
3. BMS unit
4. charger
5. much safer
6. several hundred more charge cycles which could mean years more of use
7. ability to store the lifepo4 for longer periods of time without worry of damage to cells.
heres a link to this lifepo4 battery
http://www.ebay.com/itm/48V-20AH-22AH-LIFEPO4-BATTERY-PACK-POWER-FOR-EBIKE-FREE-CHARGER-NEW-CELL-/261719115196?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2047675.l2557&nma=true&si=LDB2ki9HPIVEGhnOquu8sA%252F2akE%253D&orig_cvip=true&rt=nc
I think the main advantages for the lipo, would be less weight and smaller overall size , but unless a person plans on making their ebike into a stealth racing machine, those 2 advantages may not overcome all the benefits of lifepo4 .
On another note, I once mistakenly overcharged my lifepo4 battery to 4.1 volts on 1 cell . It did not damage it , which helps to prove the resilence of lifepo4 over lipo.
Id like to hear other peoples opinions on this. I was looking for a reason to purchase a hi capacity lipo pack for my next ebike....but after considering all the above, I decided to once again go with the standard 48 volt lifepo4 setup.
I do admit that if a person only needs to commute a short distance , then the 12s - 16000 mah lipo may be the better, cheaper option , ecspecially if the person doesnt need a charger or a BMS unit.
LIPO
LIFEPO4
3. BMS unit
4. charger
5. much safer
