If you are still looking for a sensorless controller that works well you might want to check this out.
http://www.endless-sphere.com/forums/viewtopic.php?f=4&t=13691
^^^ I REALLY need to redo those photos now that I have a better camera!
The controllers are still available on eBay for $25 + $24 shipping. (I just ordered another one.) Shipping might seem a bit high but it's typically 2 or 3 days China to USA (once they actually ship the item
) and keep in mind the controller is only $25 which reduces the pain of the shipping charge a bit.
I won't bother pasting an eBay link as they expire quickly but you can find it by searching for, "500W E-Bike Brushless Hub Motor Hall Sensor Controller", the seller "ecitypower", or visit their very confusing website at: http://www.bmsbattery.com. I say confusing because finding this controller on their website can be difficult at times.
WARNING! Communicating with these people is sometimes difficult so I always go the eBay route when ordering from them. That way at least I can get a refund if things go wrong. They try hard but don't seem to know much about what they are selling and their English is T-E-R-R-I-B-L-E!
I have been using several of these controllers for a bit over a year. Although it comes in two models, 36 and 48 volts, and is rated at 500 watts, I've been running mine at 60 volts @ 25 amps (1500 watts) for over a year without a single problem! Internal capacitors are rated at 63 volts and FETs (in the units I have) are rated at 75 volts 80 amps. Internal current limit is set to 25 amps. Motor direction of rotation can be reversed by an external jumper which is provided.
I would NOT try to push this controller much above 60 volts unless you replace the 63 volt capacitors. The next voltage limit you will hit will be the 75 volt FETS. But if you can get by with 60 volts or less @ 25 amps the stock controller will work well for you with no mods.
Best of all the regen braking works flawlessly. If you live in a flat terrain area regen braking might seem useless but for us mountain folk regen braking can be a life saver while greatly reducing brake pad wear. I prefer to dump the energy back into the battery rather than grinding away discs or the sides of the wheel! I have experienced mechanical brake failure more than once while blasting down the side of a mountain and now use regen braking to keep my speed under control rather than overheating my disc brakes and only use the disc brakes for a hard (complete) stop.
I've been running one of these controllers with a gutted Bionx PL-350 350 watt motor. I tore the internal controller out of the motor after it failed for the third time and brought out phase / sensor wires). It runs so well without the hall sensors connected that I no longer bother hooking them up. However, I ALWAYS pedal first then hit the throttle. If you are more of the throttle first type (or don't have pedals
) you might benefit by hooking up the sensor lines as there is sometimes a bit of chatter while the controller figures out the firing sequence when hitting the throttle from a dead stop. However, this controller is one of the better sensorless controllers that I've tried when it comes to this issue. The Bionx motor now cruises at 30 to 35 MPH @ 60 volts compared to barely making 20 MPH with the original built in controller!
