Chris456345234
I have have 500 watt motor (says Shengyi hybrid on it) and some unknown controller. My current pack is dead after storage in the winter (was a 'free' rebuild, I opened it and it looks like they threw in 7 of some sort of polymer batteries). Want to buy a new battery, thinking of a 13S5P Samsung 35E from em3ev with Grin Satiator and setting it up to charge to 80% as the default profile (good choice?).
https://em3ev.com/shop/em3ev-48v-13s5p-jumbo-shark-ebike-battery/
My goal: Buy something good that will outlast my current ebike, my next motor will probably be 750w or 1000w hub motor.
Few questions:
1# With only 13 batteries in series doesn't that mean the moment the battery hits 3.7v ill be under the 48v my motor expects? At what point should I expect my controller to send a 'low voltage' error (aka shutoff)? <- I know this is probably hard to answer without knowing exact motor/controller I have.
2# Is the Grin Satiator worth it, or should I just get a more basic charger that can be set to 80%? I figure with the Satiator I can setup exact profiles (max voltage and charge amperage) thereby extending the life of the batteries and use it on future battery packs. I guess the main question seems to becomes 'will the satiator last long enough to pay for itself'?
3# I might upgrade to a 750w/1000w motor in the future and it seems to be the 35e batteries should be good enough. Is this math right: 1000w divided by 48v = 20.8 amps, but this pack is 5p, so 48v/5p=4.16amps per cell. Does that mean I should still be only using about 50% of this batteries continuous CDR rating even with a 1000w motor (thereby extending the life even more)?
4# Lets say I want to store my batteries at 3.7v for the winter, can't I do 3.7v*13 = 48.1v, then just discharge my battery down to 48.1 and hope the BMS more or less will have all the cells at the same 3.7 voltage? And Ive never tried this, but can't I attach two wires to the output of the battery to an incandescent light bulb and drain the battery that way instead?
Few questions:
