TECH_GEEK10
- Joined
- Apr 5, 2015
- Messages
- 23
I have a 48v charger that I modded to have a proper charging voltage for a 36v lithium ion pack. The drop in the output voltage seems to have messed up how much current the charger thinks it is outputting and how much is actually put out. The amount of current output that is actually supplied is about ~0.8A at 36v peak, while the charger is rated for 180Watts / "3Amps at 48v" My guess is that it is sensing a "36v-type" voltage drop across "48v-type" voltage drop circuitry.
My question is do I increase or decrease resistance of the shunt to get the charger to not go into over current cutoff when it is supplying 1/2 an amp.
