Blacksword
- Joined
- Jul 21, 2020
- Messages
- 32
I am running a Cycle Analyst, a Phaserunner and a Bafang G060.750 750w geared hub motor with a 13s8p 2.2ah lg cells 30amp bms.
I set the phaserunner up for 1500w, 30 amp max battery current and 80amps phase current.
The bike works swimmingly, big grins all around until I go up longer hills, short steep hills no problem, longer drag - no sir, the CA just goes blank until I reset the battery.
All connectors are from Grin - on checking everything its connected great. The phaserunner is mounted against my frame -
Running sensorless with just the phase wires connected, not monitoring the temp of the motor right now. The phaserunner is mounted against my frame.
Has anyone run into this with this combo and is there a way to get diagnostics out of the Cycle Analyst?
