Nuts work fine for a spacer, I think I said bolts before.... I meant nuts when it comes to spacers I used.
Mine have a little wiggle but fine on the hex, low grade 8.8, 6mmx1.00pitchx65length with half threads.
Have to get matching allen black coated 70 length.
It's good to have a source for spacers if I want black spacers to match the black motor and black crank and dark bicycle frame. Hopefully McMaster Carr is shipping to Canada, years ago they didnt. I'm not big on aesthetic's, people are calling on me to buy new clothing as mine are baggy and I could really care less. Why would I buy new clothing when I am continuing to lose weight, another 45lbs to go, be spending double the money.
Yeah, thankfully those tangs helped out even when I turned it around the holes lined up.
I just need to cut off the excess.
Lots of cheap single speed chains from Chain Reaction Cycle.
https://www.chainreactioncycles.com/ca/en/chains?f=4294963590,2207&sort=pricelow
Some 1spd chains are listed as narrow (3/32), others wide (1/8)
https://www.mtbr.com/threads/1-8-chain-on-3-32-sprocket-good-ok-or-bad.497271/
Luna's gears probably 3/32, Eric's website dont say.
Doesnt look like it matters
It all went pretty smooth, 2 days of working on it with a few hrs of actually working on it and a few hrs of travel by stinky, dirty peasant limo aka the bus.
For 68mm bottom bracket. Bolt length without the head are as follows
6mm x 1.00 x 70mm are the bolts for the bent bracket with spacers on the DS.
6mm x 1.00 x 25mm are the smaller bolts for the motor back cover NDS.
6mm x 1.00 x 55mm are the non bracket DS motor gear side.
**I noticed the tapered bolt heads (Martini glass shape as the parts counter lady said) are measured differently, as the taper goes in a bit without using a washer. I see no intereference issues with normal box head so I dont know why Luna sends theirs with a tapered head in their Cyclone 3000W install video.
DingusMcGee said:
Try McMaster Carr. Here is their link to spacers and standoffs:
https://www.mcmaster.com/spacers/
Here is the link to long up to 200 mm 6mm Allen head bolts
https://www.mcmaster.com/screws/socket-head-screws/system-of-measurement~metric/alloy-steel-socket-head-screws-8/thread-size~m6/
If things are a bit too long? Grind 'me to length.
I like those tangs you made to gain length.
