The cyclone thread is from 2015. Wow how time flies. I see it becoming less popular now, hard to get and keep running all that stuff and there’s better choices like cyc and lightning rods for those who’ve learned to figure it out with the cyclone
Skaiwerd said:I didn't bother with the stock motor mount from the start. Picked up the LA ebike mount. Side plates are the same thickness as stock 3 and 5 mm, but 4 screws each not 2. But the solid chunk of aluminum makes for a solid mount for sure. It's pricey but, I know when I can't do better vs. time trying, have other things to do, you know. So I feel it was worth it. I's a bild in progress so i'll have more to report later. I have the room and I hope I can pull off this lay down low motor mounting position. It's inside the chain that powers the rear but there is room so the chains don't touch. Does anyone know how the brake switches work/install on the are sold for the cyclone? The ones that you can add to your existing brakes and Luna sells them, plug right in etc,. Unable to find much info on them.
Forgive me if the pictures don't post.
Rob
Sattva Ram said:I hope someone can help me sorry if my questions been answered but i dont want to flick through so much.
I want cyclone with regen. Now my first question is whether the motor itself can do regen?
Sattva Ram said:Unfortunately i had a my1020 bldc for my scooter but the motor itself is horrible it has so much drag that it brakes the scooter as if it was regening yet zero amps go back to the battery. Very very coggy just by spinning it with hand the scooter is hard to even push. Can someone tell me that the cyclone spins freely as a normal motor should? I'm so afraid of this after my ordeal with the my1020. I dont want to buy another dud. Mybe cyclone shat off making a proper regen able motor for it was designed for freewheel anyway..
Sattva Ram said:I want the 6kw version. Is the bicycle chain enough? Seems way too weak for such power to me. Some long term experience would be gr8 with bicycle chain.
Works. You need to delete Cyclone's freewheel also. (Convert to solid sprocket)Sattva Ram said:If the bicycle chain seems good enough i'll weld up the rear sprocket so i can have regen. At least this is my "easy" plan.
Sattva Ram said:Thanks but my question has been answered in the meanwhile. I saw a video of a cyclone benchtested without gear and it spins down nicely no cogging like my stupid my1020...seems fully regen able.
I wont bother with the bicycle setup. Very precarious system. 3 stage reduction is just bonkers efficiencywise. Even if some is gained back by the gear changing. But shifting on an electric vehicle is just untenable waaay too much hassle i dont want that...Also lotta fragile parts in the system. I will do the left side direct drive with a 10-92 25h chain setup first. However cyclone is still open robbery the 6kw no gear version costs more than the 165 qs which is a far better motor. And there's hardly any data about the cyclone. No efficiency curve nothing...cyclone seems like a dodgy company. But i just cant find ANYTHING on the market that fits on a bicycle near the BB. I wanted the qs 165 first but waay too big for left side drive...The cyclone is a very similar construction tho as the 165 qs so let's hope it's similarly good. I'd be interested in the lamination thickness of the cyclone tho..Seems i have no choice i gotta swallow the overpriced cyclone bitter pill
Sattva Ram said:I want a proper mid drive with proper chain and regen not a frankeinstein monster.............so i'll buy a standalone motor anyway............There's simply no motor on the market that is suitable for this purpose but the cyclone my hands are tied..............
DingusMcGee said:Paul of SBP told me in December that he might continue selling items such as the White Industries hubs on eBay.
My last texts with him were in Dec. this # may still work:
XXX XXX XXXX
