Aquakitty said:
omg! I need to order one. Wonder if other suppliers have them
Feature:
1, Easy installation, applicable to most normal bicycles
2, Max Torque about 80N.m, strong ramp-climbing ability
3, Internal controller + axial torque sensor (genuine two-sided torque)
4, Compact size and elegant shape, weight about 3.6 kg
5, Comfortable ride, high efficiency, less battery consumption and longer range
6, Safe, reliable and excellent performance
7, Can be connected to the Bluetooth meter directly to use APP.
Main parameters:
1, Maximum power: 350W
2, Maximum torque: 80N.m
3, Power assist ratio: 36% -300%
4, Speed limit: 25 km / h (The speed limit can be set by the instrument up to 45 km / h)
5, Rated voltage: 36V / 24V / 48V
6, Instrument program: Version 4.1 (version 3.7 before)
7, Controller: 32 bit (8 bit before)
8, Sensor: CGQ8 double head (CGQ7 before)
9, TSDZ2-NEW Additional configuration: With Bluetooth, With headlight function, With Bluetooth module
What does "CGQ8 double head" mean? Better torque sensor?
Also I just ordered 2x SW102's. I don't mind doing the "crack it open and solder" mod, but is there an issue of it not working with the motor properly? I haven't been following as I have full-time school though I am trying to get to it.
I also put a double on my recumbent but it's kind of cheating since the long chain means chainline issues aren't a problem.
So, this new version seem to be equal from the outside (motor case and display). The Maximum torque: 80N.m is the same value as previous motor version. The max motor power is rated at the same 350W. So, I bet they did not change the motor, the gears, power cables.
What seems different are the:
- Torque sensor: axial torque sensor (genuine two-sided torque), CGQ8 double head (CGQ7 before)
- Bluetooth: Additional configuration: With Bluetooth, With headlight function, With Bluetooth module
- Controller: 32 bit (8 bit before)
I would say they wanted to add Bluetooth to keep update with big brands ebike motors. As they also say they changed the microcontroller from 8 bits to 32 bits, I would say they did redesign only the motor controller to accommodate the Bluetooth. Since the previous STM8 8 bits microcontroller had only 16 kbytes flash memory to run the original firmware and was mostly full, there would be no space to add Bluetooth communications and configurations. I bet they added the new microcontroller with more memory, because was needed to add Bluetooth.
What could be the microcontroller? I hope it is a STM32 which is very popular for motor controller (like used on electric unicycles, hoverboards, electric scooters) and is very easy to program and develop firmware. Or maybe they went with the NRF5 microcontroller that is used on SW102 display, that would give Bluetooth as also the motor control (although risky here because Blueooth has higher priority and could compromise the motor control).
If anyone find a link for buying this new motor controller, or pictures, I would like to see it. Thank you.
