Apparently your sprag clutch is gone. I've once happened to repair that. You can choose the hard and cheap way and replace only the clutch bearing istself or go easy and expensive way and replace the whole gear with the clutch.michaelanthonycarroll said:Hi Narcoleptic, all,
have read your post with great interest as my Tsdz2 36V, 350W motor is also slipping. I'm interested in if you got to the root of the slipping problem.
Please see this short video which shows the slipping problem on my bike. https://www.youtube.com/watch?v=t_44mkBOOuY
The motor is switched off and it's easy to see that the pedals don't engage the motor a lot of the time. Sometime the pedals slip a few degrees, sometimes they slip for a long time.
PswPower have suggested problem is the Torque Sensor.
Other posts have suggested that the problem is the Sprag Clutch in the Main Gear.
Anyway, thought appreciated!
I assume that you don't have access to a industrial press. To replace the clutch by yourself you'll gonna need a sprag clutch itself (search for CSK30P on ebay or aliexpress), a big vise, a gas torch, a mallet and some ice cubes. Just warm up the gear really hot, then apply ice onto the bearing and then knock it out with the mallet. Then warm up the gear again, put the new sprag clutch and gently hammer it in. Then you need to quickly cool down the whole thing to prevent the sprag clutch from overheating. I just dropped the gear into a bucket of cold water.
