Retrorockit
I f that were true then wouldn't the Watts be high per speed /power produced?
Manbeer said:coming from a factory firmware example so without temp readouts and watts etc, i did 20 miles at 20mph in level 3 of 4 recently, 60 degree day, mtb with risers, 26x2.1s, total weight probably 200-210. no thermal and motor barely warm to the touch. It's going to be cold the next couple of days, but once I have a slightly warmer day I'll give it an hour long hell ride with the assist turned all the way up and 250ish human watts to see what happens
edit: What about cutting a hole in the housing and installing a blower motor like one from a computer? Depending on the voltage you could probably rig it up To use the 6v light output So when you activate the lights from the display it would turn on the fan
Retrorockit said:Manbeer said:coming from a factory firmware example so without temp readouts and watts etc, i did 20 miles at 20mph in level 3 of 4 recently, 60 degree day, mtb with risers, 26x2.1s, total weight probably 200-210. no thermal and motor barely warm to the touch. It's going to be cold the next couple of days, but once I have a slightly warmer day I'll give it an hour long hell ride with the assist turned all the way up and 250ish human watts to see what happens
The motor being barely warm to the touch is because you're not touching the motor, just the cover, which also is not touching the motor. If the cover was touching the motor (by metal,and or thermal pads), then it would get hot by helping cool the motor.
The fan is not a bad idea except dirt and water could become an issue, and a 6V fan that small wouldn't do very much cooling on a 750W motor. Even a 65W computer will usually have a 90mmx90mmx25mm 12V. fan cooling it Almost as big as the TSDZ2 motor itself.
shirk said:Something's not right with your unit.
Can you flash the factory firmware back onto it? Or purchase a factory controller with the the stock firmware and test it.
ebbsocalMTB said:I'm baffled... either this motor sucks, or something is wrong with mine. Rode the bike to work this morning again... this stupid piece of shit start overheating 3.7mi into my ride, at assist level 6, while maintaining 150-200w of motor power. My ride to work is 6.1 miles total with an elevation gain of 164' total, which mostly comes in the last 3 miles. Ambient temps on my ride were
I definitely regret buying this thing. The information in this thread made it seem at least capable of 200-250w nominal over an hour, and in my experience, it's not capable of anything close to that.
3.7 miles in, and it's starting to shut down due to heat...
.4 miles later, it's toast. been running at 100w of power since then.
I shut it off for 1 mile and just pedaled on my own.
From here, even letting it pull 50-100w of output was causing it to overheat.
So yeah... Where does that leave me? This thing sucks. I'm a tinkerer and I'm for sure willing to mess around with something to make it better or get the most out of it. However, I've got around $1,200 into this conversion and I don't even see a shred of capacity in this thing for any real cycling usage. I'm without a doubt, better off as a cyclist, and even a commuter without this thing on my bike.
I guess what bums me out the most is that I over spent in this case to buy the thing pre-setup for eco-ebike. Those guys did a great job, and provided some of the best pre-purchase customer service I've experienced in a long while (bike industry or otherwise). However, this motor is purely a letdown and if I could do it all over again, I'd just forgo buying a tsdz2 entirely.
So where to now? I'm going to tear this thing down, look for anything obvious and install the temp mods... Once that doesn't work (I'm pretty certain it's not going to work, I can't even get this thing to do 4 miles without overheating)... I guess I'll take it off the bike and sell it. I wish it were at least good enough to sell the bike whole on craigslist and profit off of the Santacruz name and lack of availability... but I can't in good conscious do that with how utterly shit this thing is.
If others are happy with this motor but you not, maybe you should try the other alternatives. I think is up to you if you want to spend your next money on any other motor or keep trying with this one. If you want to keep trying this one, I would suggest you to buy a fully new TSDZ2 and test it.ebbsocalMTB said:casainho said:Maybe this motor is not for you, maybe you should buy another Ebike with a motor from some of the well known brands.ebbsocalMTB said:casainho said:Which firmware are you using? I see reports of that issue of overheating with some new firmware.
I am on 1.1.0. I do have field weakening enabled and my cadence is ranging from 80-110. I am wondering if I should disable that... To be honest, I sorta struggle with the explanation of exactly what field weakening is doing. It's a bit over my head at this exact moment.
Here in Portugal the law got recently an update and the ebikes can now have a motor up to 1000 watts but the speed limit remains to 25 kms/h, so, anyone can safely have a bigger motor but I am pretty sure this change on the law is to target the cargo bikes <3
Meaning you're saying that this motor isn't for me because I lack the ability/knowledge to get it working properly or that it's not for me because of things specific to my usage and cycling style?
If it's not for me because of ability/knowledge... then I'd suggest it's not for most of the people buying it. I have done pretty absurd amounts of research on this thing basically reading anything that was available. I doubt most, would go down that road and while there are plenty (damn near most) that have more knowledge of electric drive systems... This isn't my first rodeo with engineering, projects, bicycles etc.
If it's not for me due to reasons regarding cycling... that's interesting. I am just struggling because I'm not totally outside of the realm of usage and window of normal conditions here. I didn't expect to be able to have this thing hammer along at 500w all day... I picked up on that much from reading every single post in this thread before buying the motor. I did however expect to be able to motor along at assist level 5-6-7ish at 150-250w of motor power and 150-250w of human power without issue. I'm not sure if that's expecting too much out of diy ebike kits?
Waynemarlow said:I think we are pretty universal here in saying the TSDZ2 may just not be the engine for him and if he says thats he's from an engineering background, then I would suspect that he from his own lack of engineering understandings. As soon as you take a standard engine and modify it then you are in no mans land other than your own.
Retrorockit said:Waynemarlow said:I think we are pretty universal here in saying the TSDZ2 may just not be the engine for him and if he says thats he's from an engineering background, then I would suspect that he from his own lack of engineering understandings. As soon as you take a standard engine and modify it then you are in no mans land other than your own.
I don't feel that way at all. The TSDZ2 is a known problem child. There is a 340 page thread telling all about it.
YOU seem to " be the shouty tell all on the internet type when it goes wrong ".
If a version of the firmware is causing overheating I think he should be thanked for sharing that with others so they don't damage their motors.
Elinx said:This is the old controller which can be prgrammed with OSFdameri said:Is this a new or old controller? ....
Here you see how componenst are placed on the new 2020 controller:
Soon I hope to start documenting the TSDZ2 motor controller V2 and start developing the early firmware for it. Meanwhile where is the repository that I will be using: https://github.com/OpenSourceEBike/TSDZ2_motor_controller_v2Elinx said:This is the old controller which can be prgrammed with OSFdameri said:Is this a new or old controller? ....
This is the "old" one:
The tsdz2 default cranks are bowed and has a relative wide Q factor.skestans said:..
What was the solution? I think I remember they could be swapped with another set of cranks that were symmetrical.
skestans said:I remember a while back seeing a post about the crank arms that come with the tsdz2 and how they’re not symmetrical: one side sticks out more than the other from the frame.
I was fine with it until recently where I started going for much longer rides (50–70km). After these longer rides, I’m getting pain in my left knee. I suspect this is due to the uneven crank arms.
What was the solution? I think I remember they could be swapped with another set of cranks that were symmetrical but I don’t remember which cranks it was. Can anyone share the reference for these replacement cranks?
