Having issues compiling the new code on windows 10.
downloaded from every source you have and always the same issue. i'm not the full bottle on arduino code so i'ts a bit over my head.
Arduino: 1.0.6 (Windows NT (unknown)), Board: "Arduino Nano w/ ATmega328"
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -IC:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\variants\eightanaloginputs -IC:\Program Files (x86)\Arduino\libraries\Wire -IC:\Program Files (x86)\Arduino\libraries\Servo -IC:\Program Files (x86)\Arduino\libraries\EEPROM -IC:\Users\vonho_000\Documents\Arduino\libraries\Wiiceiver C:\Users\VONHO_~1\AppData\Local\Temp\build1286776210805791255.tmp\Wiiceiver.cpp -o C:\Users\VONHO_~1\AppData\Local\Temp\build1286776210805791255.tmp\Wiiceiver.cpp.o
In file included from Wiiceiver.ino:55:
/watchdog.h: In function 'void display_WDC()':
/watchdog.h:68: warning: only initialized variables can be placed into program memory area
In file included from Wiiceiver.ino:59:
/utils.h: At global scope:
utils.h:65: error: ISO C++ forbids initialization of member 'HELI_MODE'
utils.h:65: error: making 'HELI_MODE' static
utils.h:65: error: ISO C++ forbids in-class initialization of non-const static member 'HELI_MODE'
/utils.h:66: warning: 'typedef' was ignored in this declaration
In file included from Wiiceiver.ino:67:
/Chuck.h: In member function 'void Chuck::writeEEPROM()':
Chuck.h:208: error: 'class EEPROMClass' has no member named 'update'
In file included from Wiiceiver.ino:73:
/Smoover.h: In member function 'void Smoover::init()':
/Smoover.h:69: warning: only initialized variables can be placed into program memory area
/Smoover.h:71: warning: only initialized variables can be placed into program memory area
/Smoover.h:73: warning: only initialized variables can be placed into program memory area
In file included from Wiiceiver.ino:78:
/Cruiser.h: In member function 'void Cruiser::init()':
/Cruiser.h:138: warning: only initialized variables can be placed into program memory area
/Cruiser.h:147: warning: only initialized variables can be placed into program memory area
/Cruiser.h:149: warning: only initialized variables can be placed into program memory area
/Cruiser.h:151: warning: only initialized variables can be placed into program memory area
In file included from Wiiceiver.ino:92:
/Tuna.h: In function 'void factory_reset()':
Tuna.h:49: error: 'class EEPROMClass' has no member named 'update'
/Tuna.h: In function 'void ui_getThrottle(byte, byte, int)':
/Tuna.h:114: warning: only initialized variables can be placed into program memory area
/Tuna.h:134: warning: only initialized variables can be placed into program memory area
/Tuna.h:136: warning: only initialized variables can be placed into program memory area
Tuna.h:138: error: 'class EEPROMClass' has no member named 'update'
/Tuna.h: In function 'int ui_getValue(byte, byte, byte, byte)':
/Tuna.h:151: warning: only initialized variables can be placed into program memory area
/Tuna.h:177: warning: only initialized variables can be placed into program memory area
/Tuna.h:179: warning: only initialized variables can be placed into program memory area
Tuna.h:181: error: 'class EEPROMClass' has no member named 'update'
/Tuna.h: In function 'void showTunaSettings()':
/Tuna.h:191: warning: only initialized variables can be placed into program memory area
/Tuna.h:196: warning: only initialized variables can be placed into program memory area
/Tuna.h:198: warning: only initialized variables can be placed into program memory area
/Tuna.h:200: warning: only initialized variables can be placed into program memory area
/Tuna.h: In function 'void tuna()':
/Tuna.h:243: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino: In function 'bool waitForActivity()':
Wiiceiver.ino:198: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino:209: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino: In function 'bool startChuck()':
Wiiceiver.ino:223: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino: In function 'void handleInactivity()':
Wiiceiver.ino:243: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino:263: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino:273: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino: In function 'void setup()':
Wiiceiver.ino:285: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino:286: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino:287: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino:288: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino:289: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino:290: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino:291: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino:305: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino:315: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino: In function 'void loop()':
Wiiceiver.ino:351: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino:360: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino:362: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino:363: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino:365: warning: only initialized variables can be placed into program memory area
Wiiceiver.ino:367: warning: only initialized variables can be placed into program memory area
