Paul_G
http://www.gizmag.com/softwheel-acrobat-fluent-suspension-wheels/31955/
Avitt said:Even in their promotional video, the wheel looks out of round. I can't imagine riding these at any speed...
Paul_G said:Avitt said:Even in their promotional video, the wheel looks out of round. I can't imagine riding these at any speed...
The SoftWheel takes one of the basic principles of wheel design, that the hub needs to be in the center of the wheel, and tosses it out....so yes it runs off center at times.
Avitt said:Paul_G said:Avitt said:Even in their promotional video, the wheel looks out of round. I can't imagine riding these at any speed...
Understood. I'm just wondering what it will feel like when that wheel is turning at 30+ mph, and the centrifugal balance is disrupted by a large bump or pothole...
I'll believe it when I see a slow motion video of a bike traveling at high speed, and can observe the compliance an recovery.
Their simulated track testing equated these gains to 16.4% extra energy that was not lost in a traditional suspension system.
SoftWheel has three versions for bikes. The premium wheelset is the disc brake Fluent HD setup designed for all around and even off-road riding, and available with either 27.5 or 29″ carbon rims. Its 3 shocks use an adjustable preload gas spring and hydraulic damping for 40mm of shock stroke. That isn’t the same as wheel travel due to the orientation of the shocks, so it’s not exactly clear how that translates to rim movement or really hoe it would compare to traditional suspension travel.
They’ve also developed a more bullet-proof wheelset with 25mm of shock travel called Fluent B designed for urban bike share programs. It includes a dynamo front and an internally geared rear hub. Lastly, the Fluent E is an e-bike version with 40mm of stroke and an integrated proprietary rear hub motor.
Final pricing hasn’t been set, but it looks like the standard wheelset should run about $2000 when they are available sometime later this year. In each of the wheels they use tech called Adaptive Rigidity that seems to be an optimized suspension tune geared to “absorb the bumps that matter and stay rigid over the ones that don’t”. How that is achieved isn’t entirely clear, but is certainly a unique take on suspending a bike.
Fluent E
Electric (Pair)
SIZES
27.5”(584mm), 29” (622mm)
SUSPENSION
– Suspension stroke 40mm
– Preload range 350-650N
– Hydraulic Rebound Dampening
– In-Wheel Suspension
– Adaptive Rigidity
– Rapid Shock-Reset
– Motor is unsprung mass
