Usually ammonia is better at cleaning petroleum-based stuff off. Or denatured alcohol.GCinDC said:i managed to get my rear brake pads operational again after soaking and wiping with paper towels and isopropyl alcohol, so that's good...
Yeah, sealed brg.ings would be better.bigmoose said:Looks like your bearing is "shielded" and not "sealed" ... that will give a path for oil leakage once the grease dissolves a bit.
Yep - essentially an immediate leak - wrong bearing type for the oil fill application. That bearing will need to be replaced with a sealed one for this to have a chance of working. Even so, the lips on the bearing seal are not equal to the effectiveness of a dedicated oil seal and so some weeping may arise, particularly as the sealing lips wear.bigmoose said:Looks like your bearing is "shielded" and not "sealed" ... that will give a path for oil leakage once the grease dissolves a bit.
I would wipe as much off as possible, then use brake-parts cleaner.GCinDC said:- will wires drenched in oil ever be solderable again? or do they just need to be thoroughly cleaned in alohol and then soldering flux?
- suggesting on prepping metal surfaces already exposed to oil for jbweld/sealant? i'm not sure alcohol will be enough. i'm wondering if i have to grind the metal - the atf almost seems to penetrate metal surfaces...
GCinDC said:my questions:
- are there better ways to protect the wiring than shrinktube? after a week of usuage, it's starting to fall apart (note that this is midsurgery for a suspected hall issue):
or should it be completely covered in a deeper layer of jbweld?
ambient was ~22C.hjns said:Any thought on how quickly the motor returns to ambient when oiled?
GCinDC said:- an oil cooled motor is not necessarily a more efficient or powerful one, is it? it's just overheats less, right?
bigmoose said:Use a nice Automatic Transmission Fluid. Dextron III is a good choice. Anti oxidant, anti foam, thin, low viscosity. Don't over engineer this. We are not marketing STP or something that gives your engine eternal life...![]()
bigmoose said:Well I think you need to keep the bearings. I would use sealed 2 sides bearings and not shielded ones.
Farfle said:Dual pie is aboit to get oil cooled, ill post up results between oil cooling and the johninCR style air cooling.
