Thanks, I needed a good laugh. :lol:bigmoose said:Well I think you need to keep the bearings.
GrayKard said:Thanks, I needed a good laugh. :lol:bigmoose said:Well I think you need to keep the bearings.
I'm considering oil cooling my next motor when I find the right one. I did an impulse buy off ebay recently of a hub motor but was pretty pissed off when I cracked it open and saw that the magnets are only 25mm wide in a 60mm wide magnet ring. Must be the low power version.
Gary
GCinDC said:seal on the drive side finally leaked, after 4 weeks?
i'll pop it open this weekend and take lots of pics.
big moose recommended dextron III and that was enough for me. i think it was actually an imitation, or replacement for dextron III.ian.mich said:what oil did you use, I've been reading about INOX MX3 and it seems to be the best despite costing 20 dollars for 300g
well, unfortunately, it's hard to tell, but i found oil inside side cover bearing housing, so i'm inclined to think you're right - leaking was due to shock, and obviously improper sealing. i'd suspected that the heat and shock would have caused my mountain of sealant covering the wires to peel away, but that was not the case as far as i could tell.ian.mich said:What do you think caused it? bearings moving around caused by shock? or some improper sealing?
i used that awesome ATF sealant around the bearing races and side covers. i only used the clear, weaker ATF sealant for wire blob and slot. i just spent some time trying to peel away the clear stuff from the stator and it was definitely on tight!teklektik said:If the source of the failure was indeed (2)/(3) then you might solve this by sealing the bearing races using a more aggressive ATF sealant as recommended in an earlier post.
well i'll be!teklektik said:The new bearing seals seem unlikely to have passed that much oil even though they are really dust seals not oil seals and lack garter springs, etc. This failure mode might be investigated further by cleaning the outside of a bearing and removing a seal to check for oil ingress.
It's got a vent/tube drilled near axle... i ididn't check to see if it was blocked but doubt it.Harold in CR said:Would it be possible to create a very slight vent for hot air to escape, without leaking ?
Just another back-seat oiler!!!GCinDC said:who are you!?:lol:
Yep - Rats. This looked like it would eventually develop into an issue but it's too bad it happened right out of the gate and to such scale. As BigMoose noted, you're better off with oil instead of grease anyway- I was planning on switching to shrouded or open bearings in my BMCs since I have exterior oil seals...GCinDC said:...well i'll be!
This strategy seems spot on. Apologies if I missed this detail in earlier posts. It takes (2) and (3) off the table.GCinDC said:i used that awesome ATF sealant around the bearing races and side covers. i only used the clear, weaker ATF sealant for wire blob and slot. i just spent some time trying to peel away the clear stuff from the stator and it was definitely on tight!
I couldn't say. We are trying to use a simple dust seal for liquids. It has a very small sealing surface and no way to apply sealing pressure except the resiliency of the seal itself (no garter spring and likely no sealing lips in the conventional oil seal sense). I have no special knowledge here but would think that anything that applied force to the seal might distort it, causing the narrow sealing surface to skew, and compromise this delicate situation - just a guess. I would think an unencumbered, free-floating seal would be best....GCinDC said:i wasn't worried about the ATF <sealant> getting on the seals cause i figured as soon as that part moved, the seal would break. i'm thinking of ways to prevent the oil from getting to the bearing. ... would it be bad if the bearing seal were fixed to the sealant?
You may be on to something there...GCinDC said:would it be better if in fact i wiped the bearing face with oil so the silicon wouldn't adhere, and then embed it in a mound of sealant anyway?
Dunno - I think you would be surprised at how little grease there was in the bearings initially, so unless there is only a smidge, it's something else...GCinDC said:btw, some clear jellyish stuff settled to the bottom of the used oil container. perhaps that's grease? or eroded bits of jbweld? or wire insulation?
duh, that's what i had. a seal on each side. also looks like 120C is max temp, so maybe that was it!GCinDC said:just looking a bit i see there are double sealed bearings?
Just to be clear - a bearing seal is first and foremost to protect the bearing itself from dust and dry contaminants - not to keep liquids out of the device in which it is installed. We are sleazing here to try to press a bearing seal to provide service in an area for which it was not intended. That said - let's see what can be doneGCinDC said:i've been looking for better bearings, but not sure what to choose from. the size is 6203 2RS. nomencature explained here.
bigmoose said:I mentioned to farfle that this could be taken to the next step since he is machining axles for the stator. You can build an oil circulation loop into the system by injecting at the axle and scavenging from out near the windings. The hub does not have to be filled for this to work if the scavenging port is played with for fluid dynamics, or you can use a scavenge pump and gravity feed. I hope the high power guys are embracing this development!
Also the guys that are using mid mount inrunners may want to get the BGSU paper that I referenced, as it shows how BGSU/Lincoln Electric optimized the oil cooling. For the 100 Hp units they re-purposed planetaries from an automotive automatic transmission.
I was able to talk with my gear expert friend yesterday and his off the cuff high efficiency reduction was planetaries. Now most have to be custom made which is cost prohibitive for us. So does anyone know a car that has had reasonable production volume that has very small planetaries in the transmission that could be repurposed?
FastDemise said:I have been running mineral oil for a couple months now. My setup is in my signature and recently went to 20s at 60amps battery and 150phase. That's roughly 4.2kW peak and 2-2.2kW continuous. Running errands ~10miles with mid 80 degree weather both the controller are just warm to touch. I prefer mineral oil due to my understanding that it's perfect for electronics and it has no detergents or cleaners added that will do any long term harm to anything in my motor. I just filled my motor with a modest 50-60mL and been happy with the results ever since. I strongly strongly recommend mineral oil (preferably the laxitive kind) cuz it's easy to get a hold of and cheap.![]()
That could work via the axle, and there would also need to be an oil-scrubber or drip-line feedback:fechter said:I wonder if there might be a way to maintin a slight vacuum inside the hub? Something like a miniature air pump with an air/oil separator. Seems like technological overkill, but would certainly keep stuff from leaking out.
