by spinningmagnets » Sep 11 2021 8:07pm
From ZeroEm
Just wondering if anyone has tried using aluminum or copper tubing flared on one end...Have the nipple fit into, thru like a sleeve
That's a GREAT idea. dishing washers seems to work OK, but having a short neck on it from the parent tubing would be sweet if it works. Don't know why I didn't think of it before.
I would recommend brake line tubing from an auto parts store as an experiment. I think its stainless steel (or at least some type of steel) and it flares fairly easy. Cut it off down a hair below the flare and it would center the neck of the nipple, while still leaving enough nipple exposed to tighten it.
Plenty of youtubes showing how to use a cheap brake-line flare tool. The brake-line flare tool can make a "double flare", but you can still just use it to make a single-flare. The hydraulic flare tool might be cheaper?
