True what you said above, if they are both essentially the same, then it won't be a problem.
But an 8 ah pack of 20c lipo won't do a lot for you.
If you are planning a very high drain, then 8 ah of 20c cheapo packs will never be enough. They will sag like grannies tits if you pull 40 amps on them. It will work, but not near as good at 15 ah of cheapo 20c, or 10 ah of better cells.
If you are just going to run something moderate, like a 1000w ebay kit with a 20-30 amps controller, then you will be fine with such a small pack. I run a 22 amps setup with no problems on just 5 ah of 20c turnigy. It does have a bit less capacity than it would if I carried 10 ah, but it's ok enough.
