Tom1977
Hi all, I bought my son a reasonably cheap pas e-bike for Xmas, he’s loved it but now asking for a throttle (illegal in uk but ok on private land) control.
The bike has a 250w (36v) motor with the usual 3x phase wires but only 3hall wires into a julet connector. I purchased a cheap 350w motor controller and throttle kit off eBay and started fitting it.
First issue was their wiring diagram didn’t match what they sent so I had to fart around for ages to get it running. It now runs but as soon as you try to ride the bike and pull the throttle the controller beeps and the motor doesn’t turn ( turns fine if I lift the back wheel off the ground). I may not have the hall wires in the correct place as I have never seen a motor with just 3 hall wires? Why is this? Do they require a specific motor controller?
It runs without any hall wires connected at all, but has same issue. You have to really ‘baby’ the throttle and pedal to stop it from cutting out, but it does eventually get quicker.
Would I be I be correct in assuming that the 250w motor just doesn’t have the oomph to propel a bike from standstill with a 12 stone lad on it? Or is it likely I have the incorrect motor controller for this type of motor. Or something else?!
Thanks in advance for any help.
Regards
Tom
Regards
Tom
