Hi guys
I read a build thread where the person replaced the stock oem phases from inside the motor with larger 6awg but removed the silicon coating and shrink wraped it to make it slimmer on all 3 phases to get them through the axle.
The shrink tubing I have is rated 125 degrees celcius, however the silicone Im removing is 200 degrees celcius. Of course the thicker wire with shrink tube is what I want but is 125 deg. shrink tube rated high enough for inside the motor? The motors that possibly will be upgraded are the qs205 and qs273.
Can anyone recommend high temp shrink tube? Dont wanna use any aliexpress tubing.
Thanks!!
Thanks!!
