At a guess, if they are fused for 10A, then some component within them is incapable of safely handling more than that. Otherwise they should be fused at whatever they are safely capable of handling.
They could have just used a random fuse, but in that case they could've used random other parts too, and I'd trust a battery built like that even less.
If they are used packs, then I'd assume the condition is very well used and not nearly as capable as they were when new, until proven otherwise by testing. There is a number on one of them that looks like a datecode (and possibly serial number) under the word HETER, which starts with 2014. If that's the year of manufacture, then assuming the cells are the same age and not older, the pack is 8 years old. Whether or not it's been used a lot in that time, calendar life is shorter now by that much, and capabilities lessened by that much as well (different for different cells, no specs on those so safest to assume worst-case). I'd guess the handwritten number on each is it's present capacity, vs the marked capacity. In this case, it means the capabilities have probably degraded quite a bit from original.
If they have a BMS, and that is marked with it's capabilities, then you can use them up to whatever those are. If it's not marked then you can try searching for whatever model info it has on it, if any, and seeing if that comes up with ratings. If not, then you can only guess. If the FETs are marked with their part numbers, you can look up what those are capable of and make an educated guess what the total BMS rating might be by that multiplied by the number of FETs, assuming they are driving them correctly to turn them on fully (if not, they won't handle the full current they're rated for as their resistance will be higher when on, and they'll create more heat). This, of course, only keeps the BMS safe from overcurrent damage, not the cells.
If there is no BMS, then unless the cells have markings and you can find a link in a search somewhere that gives the cell specs, you have nothing to go on for capabilities besides the fuse rating.
Like other chemistries, cell capability varies greatly by specific cell design/manufacturing. Some LiFePO4 cells can handle 2C fine (which would be 40A in this case, 2x 20Ah), some will sag in voltage and heat up internally, potentially dangerously or damagingly so, at that rate, and could only handle much less, such as 0.5C (which would be 10A in this case, 0.5x 20Ah).
If you have access to actual cell terminals in the pack, you can test for voltage drop under load, and test the pack at various current draws, at about half-full capacity. If there is significant voltage sag, or you have some cells that sag significantly more than others, then lower the current until this doesn't happen, and that's the limit the cells can really handle.
As for seriesing them, if they have BMSs then the info in the various threads about series BMS applies, and you'd have to decide if the risk is worth it or if the solutions in them (diodes, etc) are applicable or possible for your use case.
https://endless-sphere.com/forums/search.php?keywords=series*+batt*&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
https://endless-sphere.com/forums/search.php?keywords=series*+pack*&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
https://endless-sphere.com/forums/search.php?keywords=series*+bms*&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
If they have no BMS then you can series them like any other bare cells.
torker said:
I picked up some Lifepo locally. Wondering if I can pull 20 amps on these. They are 20 ah and fused at 10a right now. Also wondering if I can series these/how? Thanks
View attachment 2View attachment 1
