The air is less dense. Less air = less heat conduction away from any object being air-cooled, unless you increase the volume of air moved past it to compensate.
The more molecules actually coming into contact with the surfaces, taking away a bit of energy, and moving off, the faster it cools things.
This is one reason that liquid cooling often works better than air cooling, for peak load cooling purposes. (it isn't any better for long-term continuous cooling unless you're either vaporizing the liquid and carrying it off in the air, or you have something immersed in a very large amount of the fluid, like in boating applications).
neptronix said:
Their drafting is a dirty trick.. if some of you actually make it out here, we'd have to do that.. switch bikes back and forth to cool off our motors.
Unless you can make sure the motors shed heat faster than it was generated (like a human body can) then the drafting probably won't help--it'll most likely actually make the problem worse, because the motors will continue heating up inside faster than they are cooling off, and do so even faster since the lead bike's motor will always be using extra power (and wasting more power because of that as heat) to "tow" the other bike it's windshadow.
