dogman dan
1 PW
I just logged mile 5000 on my Ping battery. 2000 on a We BD 36, 2400 on a BL 36, and 600 on a Fusin gearmotor 100 on a 9 continent.
36v 20 ah Lifepo4 battery bought from Li Ping on Ebay in April 2008. After initial break in period range testing showed a usable riding distance at full throttle of 20 miles. The bike is a MTB with a Wilderness Energy BD36 on the front hub.
After a long hot summer, hot enough to melt one motor completely, My pack is still in very good shape. Heat seems to have affected it not at all. It often was charged in 100 degree weather, ridden in 105, and the garage when I returned home was often even hotter.
Having had some charger difficulties, my fault, the charging routine has been as follows. Ride to work 15 miles mostly downhill, charge there for about 4-5 hours with a sla 4 amp charger. Charger puts out about 44v. This is about a 50% discharge. Ride home, mostly uphill, using about 70-80% discharge and charge there for at least 12 hours with a 2 amp sla charger, also at about 44v. This charger was just recently tweaked to 47v.
Such a nice day today, New Mexico weather, 80f, some moderate wind, sunny, I rode a range test, pretty much the same route as I have used on other range tests including a nice big hill, and got 19.7 miles before the pack cut out. I'd say close enough to 20 miles to say the range hasn't changed any. Wind alone has caused an 18 mile range at times. I have no meter on the bike to track how many ah I actually get, but I think I can definitvely say this pack is lasting. Since not every ride is 15 miles, I am guesstimating that I have at least 200 cycles on the thing and not one shred of lost performance in 1500 miles.
By calculation, 20 ah goes 20 miles and takes one hour, my average discharge rate is around 1c, so while I may abuse and melt my motors, the battery is not getting hammered too much by my average sise motor. I have the 35 amp controller. My conclusion is that the Ping version of the duct tape battery rocks. Keep your discharge rate reasonable and it will last a long long time.
At mile 5000, a recent range test still showed great range, and using a Watts Up , the battery still takes the same amount of kwh to charge it. .80 kwh. I can't believe that as I approach and estimated 400 cycles the battery is still performing with zero detectable loss of capacity.
The ping finally died at about mile 6000. Estimated 600 cycles, on july of 2011. I had left it on a bike with the controller still turned on. Apparently this time the lvc did not work. A few weeks later, I find the battery at 6v for the whole pack. Still not bad, the battery paid for itself in the first 2000 miles, so about 4000 miles of free riding.
