I have a Ping 12v/15ah v2.5 that I use as a booster pack to go from 24v to 36v when the need arises. I didn't have any issues with this pack for several months but now I think there is a problem with the BMS.
I charged it up as usual, which means until all 4 leds are solid on the pack, and the led on the charger has finished cycling red/green and is a solid green. It currently measures:
14.22v at the charging and output wires coming from the BMS
14.33v at the battery pack (without BMS).
So there's a 0.11v loss through the BMS which may or not be normal as far as I know. The problem shows up when I apply a load. The voltage then measures:
3.22v at the output wires
14+v at the battery pack
I unwrapped the pack and inside are 4x3-pouch cells, for a total of 12 pouches. Each cell measures:
3.54
3.54
3.58
3.54
Theres an oddball in there that seems to have a higher voltage whether standby or on the charger. Other than that, I believe my BMS is faulty. Is there anything I can do to test it and confirm?
3.54
3.54
3.58
3.54
