dnmun
1 PW
yes, i had already seen the 4S BMS v2.5 signalab from ping. why did you decide to go with so low a voltage on your packs?
there is nothing really wrong with using the 8S BMS like he said, but i noticed that right away. there is nothing wrong with the output FETs. they always grind off the markings.
were you able to make the BMS work yet? i guess you are gonna try with the new 4S BMS, the same sense wire plug should work, just make sure the polarity is correct.
