Questions:
I have been looking at the setup for two different electric motorized bike kits and I have a couple questions regarding the benefits and drawbacks of each.
Kit # 1: http://www.gngebike.com/48v900wmiddrivekit.htm
Kit # 2: http://www.gngebike.com/ebikecargolfcart950w.htm
I am building a chopper style trike with 20" x 4.25" rear tires. It's not real heavy but obviously more than a standard steel frame two wheel bike.
Also I live in Vermont, USA, a somewhat hilly area. I intend to run whichever setup I build through an 8 speed mid-drive hub and derailleur just in front of my differential drive axle with a freewheel on the front bottom bracket. I went with an 8 speed drive hub to compensate for my hilly local terrain.
Question 1: Will the setup with two geared 450w brushed motors in tandem give me more torque or will the single 950w brushless motor?
Question 2: Will going for more torque to get up the hills significantly effect my top speed? I would like to achieve a top speed of 30 mph.
Question 3: I will be using 4 lead acid batteries due to their lower cost which will also add their own weight to the equation. What amp/hour battery rating should I choose to achieve a 50 mile range on flat ground?
Question 4: Which of the two setups will use battery power more efficiently?
I am on an extremely limited budget and I'm trying to do this in the most cost effective way. I do not intend to purchase the assembled kits but build my own setup with only the essential parts that are needed.
I am asking you folks for advice because my earlier attempt at building an electric bike was way under powered. I reluctantly put a gas motor on that bike and sold it. I accept my inexperience/ignorance regarding the realm of electric powered bikes and humbly ask for your expertise and experience in guiding me in this new adventure.
Thank you in advance.
