Mammalian04
My first Raptor video (that is not about problems and broken stuff) is up! Set to 1080p/60fps and crank up the music. :lol:
[youtube]HCZdJXZOTDs[/youtube]
Mammalian04 said:Offroader said:I was thinking about posting here today about what is up with Qulbix lately. I figured they may be working on something new.
Then I stumbled on a new thread of theirs.
Did they possibly release a new model, looks like an even thinner version of the 140. Looks nice. Build quality is guaranteed to be excellent.
https://endless-sphere.com/forums/viewtopic.php?f=31&t=74286
Yep! 76mm wide. I with it was 80mm so the Adaptto wouldn't stick out, or even better, 80mm inside (so about 84mm outside) but I am sure the 76mm had to do with minimizing costs of bends and welds. That's fine I guess. Better on the knees when standing on pedals.
Since you mention heartache about changing the 165, may I give some inspiration (probably a bad idea). I am ordering a Q76 and will take the rear swingarm, rear 17" wheel and Cromotor, and controller from the black 140, and I am moving it all over to the Q76. Swingarm bolts right up with no modificatons (swingarms are the same as 140).
The Black 140 will then be converted to a LightningRods Big Block kit at 64v, probably with a Lyen Controller and Cycle Analyst. I'll miss the Adaptto on that bike but I really want a full suspension mid-drive and LightningRods (Mike) has already worked up a kit for the 140. I asked about it on the Q76 and it sounds like the big block is so wide, it wouldn't helt that the frame is only 76mm wide.
So, Q76 will get BIG motor on little frame. It will be named, "Big Trouble in Little China" (I have come up with names for all my bikes because I am a super nerd like that).
140 will be big mid-drive and lighter battery for some real full suspension fun. Let's do this together with our 140s. It will be different enough from your 165.
Mammalian04 said:My first Raptor video (that is not about problems and broken stuff) is up! Set to 1080p/60fps and crank up the music. :lol:
Gsnellemin said:Mammalian04 said:My first Raptor video (that is not about problems and broken stuff) is up! Set to 1080p/60fps and crank up the music. :lol:
Sweet trails man.
drew12345 said:Mammalian what's your top speed and watts?
Offroader said:Mammalian, how bad did you dislocate your shoulder? Did you get an exact diagnoses yet?
snellemin said:Screws and plates are not so bad man. I have 7 screws and a plate on my collar bone. 1 screw in my ankle, 2 screws in my knee and 1 in the hip. Also 1 rod in my femur. I've had other surgeries, but who is counting. Just chill out on the trails. Gets harder to heal up as you get older. That is one reason my Raptor is just doing street duties now.
Offroader said:I would say at 5 weeks after surgery I was riding slowly, but maybe 6th or 7th week to ride hard. Riding actually helped to loosen up my shoulder area which was stiff from the surgery.
But I believe your injury could be worse if you damaged some of the stuff around the shoulder like ligaments. What I learned is that unless you really need surgery sometimes your better off giving it time as surgery can make things worse. But it depends on what they find and like with my broken collar bone I had no choice.
I would also seek out the best doctor. I flew cross country to Seattle to get my collar bone fixed from one of the best surgeons I could find, he has fixed over 1000 of these and uses the best procedure a flexible rod instead of a plate and screws. I'm going to get that rod out as soon as I can because it pokes the skin at one spot and is irritable with weight placed on it, like even heavy winter clothing. But because it is a rod it is easily removed once the bone is healed enough. If I would have a plate it may have been worse as many find the plate very irritable. The plate also is more difficult to remove as it is 4-6" long.
I know from researching doctors that the best orthopedic doctor for dirt bike injuries, lots of shoulder, knee, collar bone is Dr. Mark Sanders from Sandersclinic and is in Houston. I'm not sure how far that is but I would without doubt go see him if possible. Lots of people fly to have surgery with him.
