LewTwo
OK ... so I have ordered a 6 inch long 12mm hex key with a 1/2 square drive.
(My Husky brand Allen Wrench set only went up to 10mm).
I do not want to make it any tighter than it already is.
Stupid question:
Which direction to rotate the wrench to loosen it?
For inquiring minds: Why do you want to remove it ?[/i]
Well I have already gone to the trouble of removing the skewered 10mm axle, bearings and nuts because I want to replace it with a solid, nutted axle (assuming I can find the right pieces-parts .... Chinese vendors are damned short on dimensions of their products). That only leaves the Freehub installed in the wheel and I have no previous experience with them. I figure this is a good time to pull it out and have a look-see. That way I will know what I am dealing with should I have a problem with it in the future.
Stupid question:
