Hey Guys!
So I'm going to be rewinding a 9C motor. It's one of the older ones not sure exactly which, but it has 63 teeth on the Stator and 56 Teeth on the Rotor. It's wound AaABbBCcCAaA.... with 6 Strands 6 Turns.
I want to do a silly slow wind so I'm going with 14T. Now my question is.. Does it matter how the coils line up wrt to the Halls? As I am aware the halls are independent of the coils and are spaced wrt the magnet rings. So essentially any starting position for my wind should work. I've got it so the outer two halls are going CCW on a and b on the hall teeth and the centre hall sees CW AB on the two side by side Teeth with hall in centre..
Is this right?
Here is a picture of the motor before I started. I'm done 2 phases now. Going to terminate in WYE.
Is this right?
