Single Chip BMS Research + DALY Pin Compatible BMS's
Finally success.
Now I can share my data via the server. It took me almost as long to set up this s*** as it took me to build iot from scratch
-methods
That was so much pain.
When you do it
* Use the app
* Log into YOUR wifi router, not ITS hotspot
* Give it your password (c o u g h)
* Then it magically just happens
What is going on is the phone app is backdooring the dongle and stuffing your SSID and Password. After that, if you already set up your online accounts, BAM. Data in the cloud.
-methods
So sketch
You can literally change current limits remotely
* I'm removing the dongle
-methods
Ok, back to BMS's
I need one, like yesterday.
-methods
Point of all that?
* If you wanted to hack the GroWatt protocol, all you would have to do is sniff the UART
The interface between the WiFi dongle and the Inverter is USB. If you inspect closely you will see it converts to UART. If you simply attach GND and TX to the GND and RX of an Arduino and pick the correct baud, you can start spilling ONE SIDE of that communication to the terminal, where you can later parse it.
If you use a second arduino, or a second uart port, you can then grab the other side of the communication. OBVIOUSLY it is easier if you synchronize them (L O L) and I suggest doing it on a heartbeat. I.E. if you just log the ASYNC data you will have no way to line it up. If you instead log against a heartbeat you can line the two data streams up.
You then initiate
* Like sending a command
You then watch the 5 or 15 back and forths
Now you have a backdoor into the GroWatt - and - this may be at the AT command level or .... right? Because it is a standard WiFi nugget they have on there. The USB is THAT interface, the one between the actual WiFi node and the uProcessor, so that means
* That the language being spoken will comply with the datasheet of the WiFi "chip"
* I.E. that is what all the garble is wrapped around the snips of data you want
-methods
And
remember that I already posted a GitHub link to someone who re-programmed the WiFi dongle and hacked it to send to MQTT instead of the Jenky-ass GroWatt servers
C O U G H
Which is E X A C T L Y what I was wanting to do some many months back, so thank you to that person. Now we can use our own IoT to bang-bang with the SPF 5000 ES with far less worry about some clown logging in and changing Current Limits (barf).
* GroWatt Servers - big target
* methods super one-off IoT bungle, H A!
Nobody is ever going to waste the time or energy, if they could even find it among the trillions of other smart devices out there.
-methods
0320 local
Now to find that BMS
Starting with clue HLZT
-methods
That is what you call a dead end... maybe
-methods
Source: https://www.indiamart.com/proddetail/40amp-bms-board-23845642912.html
Source: Google Search of HLZT
-methods
Here translation courtesy of Google
Parents today stamp of authenticity, day after Thanksgiving, North America, ~0330
You'll find that picture nowhere else on the internet. That's the same desk going back to the beginning. BMFW has not changed either.
-methods
Sometimes if the characters have too much meaning, the augmented reality doesn't render that well
Starting in, traction is good
Google is giving me some real go fish
"HLZT Shenzhen Hailong Zhitong Electronics"
So high street lighting is doing the import, but it is clear that this is not their primary gig. Ignore these informations, this is seller on indiabahbah not mfg of bms
-methods
Ok, two screens going
Currently on
Google Image Search
"HLZT BMS"
Looking for a visual match on the sticker. H I T
-methods
This is our friend from the Revolution, 3rd variant.
This is not a one-off, this is production
Why do we not find yet yes?
-methods
STOP TIME
This smalltime website has both the BMS and the Batteries shown in the teardown video
https://www.electromannsa.com/es/products/4s-12-8v-lifepo4-3-2v-battery-750a-bms-battery-protection-board
Zero doubt, the exact cells shown
https://www.electromannsa.com/es/collections/miscellaneous/products/life-po4-120ah-3-2v-lithium-battery
Code:
Charging
Charge current: Same as continuous current
Charging voltage:12.8V (Nominal)
Over charge protection
Overcharge detection voltage:3.7V±0.05V
Overcharge release voltage:3.6V±0.05V
Overcharge protection delay:600uS
Over discharge protection
Over discharge protection voltage: 2.2V ± 0.1V
Over discharge release voltage:2.5V±0.1V
Over discharge detect delay:600uS
Discharge protection
Instantaneous current: continuous current * 2.5
Overcurrent detection delay:600uS
Over discharge detect voltage:100mV
Overcurrent protection release condition: Disconnect load
Short circuit protection
[b]Short circuit protection condition: External load short circuit
Short circuit detection delay:600uS[/b]
Short circuit protection release condition: Disconnect load
Working Temp
temperature range:-20℃/+80℃
Package Contents:
1 x 4S 12.8V LiFe Po4 Battery 3.2V Power Protection Board 75A
Uh... South Africa?
WTF Bro
https://www.electromannsa.com/es/pages/contact-us
First by me
I shizzle, its like a clearing house. Somehow this dude got a line on the batteries and bms. Proceed with great caution.
-methods
Oh SNAP
Same shitbird in blue now
-methods
Now I am just doing depthcharges into the website search portal
https://www.electromannsa.com/es/products/90ah-lithium-lifepo4-45amp-12-8v-rechargeable-battery?variant=43390250189041
uh.... bro
-methods
SQL style search works
https://www.electromannsa.com/es/pages/search-results-page?q=bms
-methods
Ok, so on a hit like this I am seeing no mention of how high you can stack these. That is a very important factor, and a great sign of reliability. AFAICT, this 4S BMS can stack 16S
lets compare costs
Ok, $60 bucks
-methods
Thru the original Google Image Search
https://www.electromannsa.com/products/13s-50a-3-7v-48v-lithium-battery-charger-protection-board
13S 50A
Difference is that it has some hand tagging on it
-methods
Oh nice, actual potting
Unlike the shoe-rubber I found in the DALY turd. DALY is not a friend of the revolution. If you rip off methods, you are not a friend of the revolution. methods may rip you off by selling you some swap meet louie, but cant go other way around
[youtube]Q0IrjFamL2c[/youtube]
Go big or go home
Time is 0420 PDT
-methods
