Single Chip BMS Research + DALY Pin Compatible BMS's
Yeah right
If you believe that I've got some rhinoceros pills to sell you.
-methods
Ok, getting closer
https://www.whzhitong.com/
No Dice
Maybe firewall issue
-methods
Now just searching subphrases
... 100% HIT
https://powerforum.co.za/topic/5439-mecer-lifepo4-lithium-ion-batteries-any-experience/page/4/
:bigthumb:
Key words do not even match, but there is a decompile in there.
-methods
Ok, same setup under a different brand name
I guess AmpTime is just ONE retail name
https://www.mecerpc.co.za/Mecer-SOL-B-L-M200-p-239794.php
ok, 6 pages in
https://www.hubblelithium.co.za/s-series
Nice
Note that internal impedance is BMS mosfets PLUS cell series resistance, you do not want to mix that one up.
Now I am on to this search term
"Mecer BMS"
Somebody is repairing these...
-methods
SSSSTOP
Same name different shape
I have to reset the Image Search because that BMS is what we are looking for but looks nothing like it.
-methods
https://www.jst.com/products/crimp-style-connectors-wire-to-board-type/eh-connector/
Nah
Lets measure it out
-methods
It's more like 1 mm pitch
My caliper battery is dead, eyeballing it.
There are very clear markings
Not all the same
-methods
LHE shows up on the right side on both
Other side gives up DX and EL
So far
-methods
[youtube]v0PVu9MC8fQ[/youtube]
Nice commercial for counterfeit garbage
-methods
See how I make that jump?
Extract the pitch, look for what is common
-methods
SOLVED
https://www.jst.com/products/crimp-style-connectors-wire-to-board-type/gh-connector/
-methods
NEGATIVE
NOT SOLVED
Link
https://www.aliexpress.us/item/2255800531480800.html?gatewayAdapt=glo2usa4itemAdapt&_randl_shipto=US
From here
https://diysolarforum.com/threads/i-need-a-daly-8s-cable-assembly.28922/
Doh, I read caliper wrong
-methods
Seems like 1mm pitch
Definitely locking
Definitely wire to board
Everyone is saying 2.0mm pitch
OMFG I was reading tenths of inch
Definitely 2mm pitch
That has to be a JST PH 2.0
-methods
Nope
But this is what I use now. I use 2mm pitch on almost everything. Here are odd wire to wire that are not solder-butt
https://www.amazon.com/Connector-Pre-Crimped-Compatible-JST-PH2-0mm-Inductrix/dp/B08T89ZK2Q?th=1
-methods
So any 2mm pitch connector will fit this. If you want the lock, you have to find the match. These are all over NastyBahBah, so super common stock.
-methods
https://www.scondar.com/wire-to-board/yeonho-2mm-pitch-connectors/
-methods
Ok, so an SCT 2006
Sigh
Another JST clone
Here is the full cross reference above
-methods
Yeonho 2.0
SCT2006 Series
HY 2.0mm
HIT
https://www.newark.com/jst-japan-solderless-terminals/vhr-3n/wire-board-connector-receptacle/dp/68C2105?gclid=CjwKCAiA7IGcBhA8EiwAFfUDseWXPpqWi2Rq_EKqKfqVprTZy9ltlGua5orJEo622M1tda6jw9QqEBoC0uIQAvD_BwE&mckv=_dc|pcrid||plid||kword||match||slid||product|68C2105|pgrid||ptaid||&CMP=KNC-GUSA-GEN-Shopping-PMAX-Med-ROAS
-methods
Nop, pitch is too wide
I use this page at times
https://www.mattmillman.com/info/crimpconnectors/common-jst-connector-types/
Good page....
-methods
Look around...
Right?
-methods
You can literally only get this as counterfeit... So how about we terminate the search?
-methods
Same LHE, now an FM
So one stamping has not repeated yet, other has stayed the same
https://www.lhecn.com/category/wire-to-board/2-0mm-pitch/
There they are, safety and benefit
You can go swim in this...
https://www.lhecn.com/a2005/
Only goes up to 16 poles
-methods
  • A2005PHB.pdf
