DAPU M155 rear hub motor had an axle spin-out After which:
:REENTION EEL Pro Activates as normal
King Meter KM5S-R: Switches on, accepts RFID tag and activates
- Long press up fails to activate lights although light icon flashes briefly on display
- Display shows 0.0km/h speed only
- After 10 mins the display shows 33 then switches off. Error code 33 Display Communication Error
- With display off battery will not shut down with long press. Display must be reactivated then long press battery on/off shuts down both the display and the battery.
I checked cable harness to Motor and as you might imagine there was some damage to wiring insulation no wires were broken or detached. I repaired wiring insulation damage. Continuity test on hub cable harness wiring revealed no problems.
Everything I am doing I am learning for the first time, which has been fine, though I think it prudent that I should seek situation specific guidance as im "you-tubed out".
BTW : My controller has no identifying marks on the outer casing. I have not opened it....... as yet.
Any feedback/advice/divine intervention welcome. Thank you.
