dogman dan
1 PW
Good to hear you can still ride.
What I meant by pedaling, is really pedaling which it sounds like you do. But even so, you might consider lowering the seat an inch, leaving you floating above the saddle more when pedaling briskly. Maybe your injury is a result of a too high seat, or maybe you have a pedal forward bike? Learn to ride using the seat as a thing you lean on to steer more than a thing to sit on.
Shorts will help a ton with chafing, but if you are still jamming you taint into the saddle hard, you will reinjure it. Shorts won't fix what caused you to piss blood, unless it was the pants seam on jeans getting jammed into your uretha. Even if it was just the seam causing the problem, you were still sitting too hard on it. Floating on the saddle is why I could stand up to 30 miles a day in jeans. No jamming that seam into my taint.
