ebikeman123
- Joined
- Mar 26, 2018
- Messages
- 25
Allex said:ebikeman123 said:Imho the Sur-Ron, even with belt-drive, is too loud. It is strange that the motor makes such a whining sound. A direct drive hub motor used as a mid-drive seems to be a better solution. The cyberbike or the vector vortex for example are almost completely silent.
It is not the motor that makes noise, there is two things:
Surron have two stage gear reduction, here you have extra noise and then you have a huge sprocket on the hub motor in Vortex. Chain on small sprockets makes more noise than on big ones because of the higher chain speed.
Yes, but no. There is noise from both the motor and the chain/belt-drive. About 50/50 I would say. That sur-ron motor screams compared to a typical direct drive hub motor. It is the difference between normal people staring at your bike or not.
