liveforphysics
100 TW
gestalt said:I got a chance to go over one of the large packs that a123 uses and it seems that they sandwich the cell between two sheets of aluminum for heat syncing. and between each of those sandwiches ~~mmmm, lithium sandwich~~ there is a layer of a neoprene like material to allow for expansion. I was told that the cells can expand about 10%, have you seen anything like that in your tests?
I've not personally measured or observed any cell expansion, but I've not been looking for it either. I assume the expansion is purely a thermal thing, and not related to SOC?
I will sandwich a cell between some of my fancy carbon fiber sheets, heat it up, and document a rate of thermal expansion.
bigmoose said:Luke, my hats off to you! Stunningly great test, the thermal images are priceless. Glad the FET switcher electrically held together. Sure appears that without any doubt these cells are the real deal
Ohhhh, how I love the aroma of high power electronics in the morning
Ah, I really like the thermal images Luke, can you share which model Fluke Imager that is? What's the interface to get the thermal images out of it? How flexible is setting up the image to print the localized temps over the thermal map? The more I look at your pix, the more fascinated I am with the images.
It's this little guy:
http://www.tequipment.net/FlukeTi40FT.html
With one click you can set it to lay a grid over any IR image that shows the temps at every interval spacing that you set. It always makes the IR photo look like a spread-sheet with a colored background though. lol Otherwise, you click the "manual temp tag" button in the fluke software after the image is on your computer, and it throws a temp ID marker anywhere you click, so it's just as quick and easy as clicking a mouse.
Focus is bizzare with IR, and the angle you hold the camera in relation to the object you're viewing can cause some bizzare artifacts that show up as silver-grey blocks. I'm actually a certified Infrared Thermographer. lol It just means you sat through a couple 8hr classes while a bone-head instructor talks to you like you've never before heard of the concept of wavelength and emmisivity... On the bright side, I think at the end of the course, the instructor had a better understanding of the subject he was teaching. I politely asked a couple of questions that lead him toward gaining a deeper grasp of the subject he taught.
For things that fit into my lunch bag, it's very easy for me to get IR pics of them if you have anything you want to see in action. It's a high security datacenter, so it's very tricky to bring in larger things like cell testing equipment lol, but small things are cake.
