Dnmun, Please have a look at the posts. I have not asked for your technical assistance, yet you sought to force it upon me. I am perfectly skilled & capable to diagnose any issues related in this thread. My post was an inquiry about a businessman and any experiences others had with quality issues. To be clear, I did not ask for your help. In fact you have not been helpful, but rather aggressive, rude and taunting. I am guessing you must suffer from a malady such as Autism or Asperger's disorder as you seem to possess some technical knowledge, but not the wisdom or insight to carry yourself respectfully. I will cut you as much slack as possible given the level of personal attacking you are engaging in and try to explain just once at a level I hope you may comprehend.
“so kopp guy, i don't believe you.â€
Your behaviour so far in this thread been as poor as to ensure I don’t care what you think. This is why you have been ignored in this thread so far. I now only feel pity for your ignorance and shallow thought. This pity is why you are even getting this response.
“if the sense wire had been disconnected originally the pack would not have discharged at all initially.â€
Correct, as clearly stated the failure happened after the second use.
“you lied.â€
If it in some way makes you more comfortable in life to believe this then keep believing it, however, I have not. Try to understand publicly accusing another person of lying is generally insulting and will not win you any favour with anyone.
“you broke the sense wire when you took the pack apartâ€
Your perception of the order of events flawed my good fellow, I dissembled the pack to accommodate Ping & get to the root cause of the failure.
“it was not broken during manufacture or it would not have worked for them when they tested itâ€
Again correct, however, you have again overlooked the fact that I said the battery functioned for two cycles then failed.
“you don't have clue.â€
Again my good fellow, publicly saying these sorts of things is generally insulting to anyone who reads them. It is this is the sort of statement that makes me believe you have a neurological affliction. You would be better suited in life to refrain from these outbursts.
“you have never owned a pack beforeâ€
True, I have never owned a Ping Battery.
“don't have the slightest idea of how to diagnose what is wrongâ€
I understand you must feel the need to assert yourself as the dominant technical authority in the world you perceive as yours, In this case, your statement demeaning another helps you to this end. But understand, everything you have learned has already been learned & forgotten by someone before you. Humility is not such a bad thing my good fellow it will take you many miles farther than allowing yourself to engage in such outbursts.
“trashed li ping for no reasonâ€
Every item I have brought to point is accurate and with reason, there was no “trashing†whatever that is meant to indicate, every detail is a key point of an unfortunate quality control failure. Even exposing me to your attacks via this post has reason. In keeping with trying to help you understand, I will share some of my reasoning and desired outcomes.
First, I enquired via this post if Ping had been known for even occasionally sticking a customer with a poor quality product; I wanted to know so that I might adjust my handling of him accordingly. The responses I received indicated he is responsible & honourable; therefore I was able to interact with him on a more sedate level than I might have otherwise.
Second, as we all know the many in the world turn to the internet for information, this forum is one of those sources. I have used this forum, and wanted the good feeling of contributing, even if that contribution is an unpleasant subject, I knew the subject would be of interest.
“now you are trying to cover your ass for tearing the pack apart.â€
Again, I encourage you to endeavour to control your self my good fellow, such outbursts will not benefit you.
“you just want someone else to pay for your mistakeâ€
Again, self-control is your friend; such outbursts are generally considered insulting and will serve you no good in the end.
Again my dear misled fellow, this thread is a recount of a series of unfortunate quality problems that led to a failure of a product. There was never any question of mistake, there was no mistake and the unit is warranted. Also I am protected by the payment service; there is no point to the statement.
“li ping is an easy targetâ€
It is clear by your outbursts it is I who is being regarded as the easy target.
Mr Ping is a businessman who represented his product as “excellentâ€; I purchased his product based on this and his visible reputation. The product I received did not measure up to “excellent†I have "called" him on it so to speak & he has responded well so far.
“because he bends over backwards to make sure no customer is unhappyâ€
I applaud him for this. It is a great quality. I am sure it will serve him well overall, it is a sound business stratigy.
“fan works when you tilt the charger this way or that. sure, what a joke.â€
Goodness, these outbursts will surely be your undoing.
Again, such statements are considered insulting by most and will not serve you well, but I suspect you probably already know this.
Dnmun, I encourage you to seek some help with your anger issues, your world must be truly stressful and I suspect your quality of like has suffered for it. One only has so much life granted to them to waste even as much as you have in this thread alone being so angery is trully sad.
It is my hope that the time I have now donated to your specific anger issues helps you understand there is nothing in this thread for you to be angery over and may someday benifit you and help you find cloesure.
