sulphuric99
I've put about 100 miles total on this kit mounted to a plain steel frame, no suspension mountain bike with 26" wheels. Bike pictured here: http://www.endless-sphere.com/forums/viewtopic.php?t=2179
With the 36V 12AH SLA's that came with the kit, peak speed on flat ground was 20MPH using 26" Continental "Town and Country" tires. (With plain MTB nobbies, I remember the peak was around 2-3MPH lower, but they sure had grip!) I never ran the SLA's all the way down, but after 14 miles of pretty much no pedaling the bike's speed and acceleration was noticeably slower. I would feel comfortable going around 15 miles on this kit without pedaling.
Today I went for my first real ride with a 12S4P A123 pack (39.6V 9.2AH). Wow! Acceleration is noticeably improved, and my peak speed is around .5-1MPH faster. Also, unlike SLA's, I didn't notice a drop off in peak speed/acceleration anytime during my ride. Some specs with no pedaling, typically going at max speed whenever possible and safe, flat roads:
Total time: 79 minutes
Total distance: 16.25 miles
Average speed: 12.3mph, Max: 25mph
Rider weight: 135 pounds
After the trip, I immediately recharged the pack using a Hyperion EOS 1210I-A charger. It reported 7.588 Ah used to recharge the pack to full. Assuming 85% charging efficiency (wild guess), this works out to around 6.45 Ah of capacity used for my ride, or ~255 watt-hours at 39.6v (I don't have a watt-hour meter like the Drain Brain yet, so this is the best i can do.) So this works out to around 16 watt-hours per mile. (This value seems a bit low given the specs I've seen posted - do these specs sound wildly inaccurate to anyone?)
Overall, I'm pretty satisfied with this kit. Except for a bit of dropout filing, it was easy to install. If I was going to do this again, I would just skip the SLA's entirely and spend the money on another Dewalt pack.
Some downsides:
- Some of the hub motor's spokes where a bit loose, and the wheel didn't spin true out of the box. I've mostly fixed this, but a couple of the spokes still feel more loose than I would like, which concerns me.
- The default thumb throttle becomes sheer torture after a few minutes of holding it down.
- No battery fuse is included with the stock kit (!).
- I wouldn't take the stock kit out into the rain without sealing, taping, or covering everything up. The controller especially didn't look completely sealed to me (<i>mostly</i> sealed, but not quite 100%).
Some recommendations as you are installing the kit:
- The SLA's that come with the kit fit pretty snugly into the included battery bag. I put some thick cardboard beneath the batteries, and some thin cardboard in between each one. The cardboard acts like a last resort shock absorber, reducing stress on the batteries when going over potholes, jumping curbs, etc.
- Tape the battery wires in the bag down to the batteries, and ensure all the connectors are tight. I had the connectors come loose a few times on my early trips.
Some downsides:
