Butch1 said:
Hello all, my setup is a Bafang 250 watt rear hub with no hall sensors, bike just quit, battery is fine, battery connections are fine, brake cutoff's are fine, wiring looks OK.
the most common causes of sudden system stoppage are battery failure and wiring problems.
since there's a lot of possibilities, then before we can really help, we'll need some clarification.
what specifically does "bike just quit" mean?
did all power fail, meaning that all lights, screens, etc., turned off, as well as the motor stop working?
or did lights/screns/etc stay on, while the motor stopped?
the former indicates a problem with power, either the battery not providing power to the system, or the controller no longer being kept on with it's ksi "keyswitch / ignition" input from display, switch, etc.
the latter indicates a problem with many more possible sources, depending on the exact symptoms and the resutls of various tests we can point you to once we have more details.
OK, I was riding along and hit a few rough bumps/potholes, bike kept going fine for another 2-300Ft or so then shuddered a few seconds and quit. Usually this meant the battery connection got rocked loose but I never lost power to the console at all so I know power if flowing to the controller since the LED console gets it's power from there. Pedaled home and started looking at the 3 phase wiring to the motor, (it has no hall's) everything looked intact. Checked wiring from PAS, brake levers, nothing looked out of place or chafed, I think it's possible I might have upset the controller with the bumps, it is 5ys old at least, low power setup though so a 250 watt motor doesn't ask for a lot current-wise. I'll find out more tomorrow with a visual inspection of the controller and will post back, thanks for responding.
next:
by the various parts being "fine", what exactly was tested, and how?
