Bigwheel
Until something that is torque assist and throttle able and not $4k I am stuck with the TSDZ2 system it seems. My first lasted 1000miles of pretty hard off road use/abuse until the weak bb bearings became unbearable to ride. My second one, $350 and easy to replace has about 500miles of the same but the other day the blue gear ate itself....
I do admit that it was a very strange situation that caused it in that I was following a sketchy elk trail here that started to really fade out and decided to turn around. Upon starting off I did my usual blip of the throttle and leg over routine and had just started to pedal and had let go of the throttle when my front end dove into a hummock of grass and I stopped dead in my tracks, probably never made it over 3mph so no harm there.
Got back on track and went to blip the throttle and bzzzzzzzzzzzz. I knew immediately what it was but it took a minute to process the info because it was so benign an action. Torque assist still worked, albeit with some crunching, at least enough to get me back to the barn with some time spent pushing back up over the hill. I had the brass gear from my first motor in stock so I installed it and although the motor is noisier I don't expect to have that issue again. But the bb bearings I do expect to fail.....
