Arlo1 said:
HumboldtRc said:
I just noticed that they changed the specs. It now says "20v Non Load Current: 11A" so 220 watts to spin is not that bad.... Way better than 17amps no-load current.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14427
11 amps @ 20 volts is rediculious!
yes indeed, it does sound bad.
but rpm/amps wise i think the colossus wont be much different, and i think its just how it is when the diameter is this big, its the (very roughly) 100kph magnet past stator limit thing that ive been banging on about.
and actually its more like the number of poles past stator that matter and this motor has 24 mags making the the count (and surface speed) very high even at only 4000rpm, between this and maby 5500ish rpm (without extra cooling) would be all you would want to get to with this and the collosus in my opinion.
also the (way too high) 150 rpm/volt of this motor makes the situation LOOK twice as bad, so dropping it to 87rpm/volt with wye is the go.
dont get me wrong though, still plenty of power to be had though.
and is there an advantage in the low rpm and high torque area by having heaps more magnets? there must be a good side to offset the above costs in rpm limit??
