madrian
- Joined
- Nov 23, 2022
- Messages
- 12
Hi. I disassembled my escooter battery and found that several contacts were broken. I repaired it with my spot welder. The second problem is that the battery pack is unbalanced and the charger shuts off before all the cells are charged to maximum voltage. I found out that 3 cells are at 4.15V while the rest are at 4.05V.
Should I leave the battery connected to the charger and the BMS will eventually balance the cells?
