voicecoils
methods said:Did you not have that bolted down
I can hear the wife screaming at you now while you try to explain the scuff marks going all the way across the room.....
Would have made for great video!
So was that wobble caused by the axle sliding side to side in the stand or from hub being off axis?
-methods
On an unrelated note, I came across a bizarre sea creature while image.googling for something totally different:
Now, back to the topic at hand. If I had bolts I'd bolt it down. Gotta get some lug nuts from supercheapauto, thanks for the heads up.
The wobble was mostly from the truing stand not being stiff but a little in the disc / sidecover. I have to double check that the disc is dead flat. If it is, I'll pop the sidecover off and 'shim' it from underneath. Probably a bit painstaking but the result should be a dead straight / true disc.
My girlfriend was not around to roll her eyes and run for cover.
