Drunkskunk
keep them half dead and Stick them in the fridge. They only lose 2% capacity a year at nominal and 32 degrees F
Drunkskunk said:keep them half dead and Stick them in the fridge. They only lose 2% capacity a year at nominal and 32 degrees F
Mark_A_W said:I tried that with both my Lithium Manganese pack and my Lipos - whenever I could. I used to charge the batteries then stick them in the fridge.
To tell you the truth I think the temperature cycling made it worse not better.
Keeping them in the fridge doesn't work for a battery that's mounted to the bike, or one that needs to sit on the charger all night to balance.
Almasi said:Mark_A_W said:I tried that with both my Lithium Manganese pack and my Lipos - whenever I could. I used to charge the batteries then stick them in the fridge.
You should leave it half charged (3.7Volt for Lipo) if you store it...not full charge
Robin
Mark_A_W said:Bit of both, but they basically die in a year or a year and a half sitting on the shelf.
All my bike and plane lipos are dead now.
voicecoils said:
Almasi said:voicecoils said:
You are sick if you have a frame like that just for backup But it make sense if your ride it like it should
recumpence said:Hey, the word "Mature" is rarely used in the same sentence with my name. :wink:
Matt
recumpence said:Mark_A_W said:Bit of both, but they basically die in a year or a year and a half sitting on the shelf.
I have lipos that are 5 years old and still work fine. I even store mine at full charge sometimes with good success. I have heard of various experiences, though. It seems like everyone is different. The best thing is not to let them sit more than a few months at a time. If you do, it is best to be easy on them for a few cycles untill they "Wake Up". After that, they are fine.
The only problem I have had with storage is if they are stored for vary long peroids without any cycling. But, that normally takes about 3 years in my case. I have found, if they are cycled regularly, lipos last a loooong time.
Again, people all have different experiences with various chemistries.
Matt
recumpence said:Yes, I normally buy high end lipos. I have some cheap ones now. We will see how they hold up. :wink:
Matt
voicecoils said:for the new bearing kit I got.
Almasi said:voicecoils said:for the new bearing kit I got.
How much was it? From where? (I intend to change mine soon )
Robin
Mark_A_W said:Or you could just buy bearings from a bearing store.
