El_Steak
Lets say I have 2 motors. One is high rpm / Volt, the other is low rpm / Volt
The high RPM motor allows me to roll at 30mph at 50V, using 30 amps (1500 watts)
The low RPM motor allows me to roll at 30mph at 100V, using 15 amps (1500 watts)
To simplify the question, lets also assume that both motors have identical efficiencies at 30mph at their respective voltages.
Will the high RPM motor using half the voltage but double the current generate significantly more heat than the low RPM motor?
