chas58
What do the 3 speed PAS settings on a controller actually do?
Basic controllers (i.e. KU65 from BMS battery) have a 3 speed switch for the PAS, that offers slow, medium, and high speed.
How do they do this? Are they limiting the voltage to limit the speed?
For instance, at 36 volts, do I get 12 volts, 24 volts, and 36 volts?
This would mean reduced power at the lower speed settings (and reduced power consumption)
Or are they more like a throttle that once a motor reaches a certain speed, the controller just cuts the power (actually allowing it to taper off).
And part 2: I assume the “torque sensing controllers” (bms battery S06) moderate the current and keep full voltage? Thus, I would be getting 36 volts, but might get 5, 10, and 15 amps at different settings?
