okrobie
I have recently refurbished a TaoTao E-Scooter Model number ATE-501 with the help of friends on this board. It has 4-12 Volt 18/20 Amp Hour SLA batteries. I recently acquired a variable voltage power supply which can be adjusted to a maximum voltage of 53.5 VDC I tested it on the batteries last night at 53.5V and it started charging at 2.5 Amps and dropped, as the battery charged, to zero when they reached 53.5 Volts.
My question is, should I be charging this high or higher? Or should I adjust it lower? Thanks
