This forum is a wealth of knowledge and I have studied it at length. Many things would be easy for me to answer but my problem is one of maybe's and possible range bias.
I would to know the answer to paralleling two batteries. The reason is for voltage sag and ultimately pulling a bit more watts because of higher voltage drop. That may be where my bias is clouding the issue as that may not balance out in the overall picture like I hope it will.
I have two batteries. Both batteries are about the same age and both are GA 3,500mah cells. Not positive they are the same manufacturer (both red cells) Both batteries have 30 + amp bms
Battery one is a 14s4p with about 270 charges total and can be charged to 58.5 volts. I recently pulled 501 watt hours out of this battery (10.8 ah) at 300-550 watt draws before the battery reached 43 volts. Upon sitting the battery returned to 46.6 volts after an hour. The BMS did not cut the battery out and I was still asking for 300 watts out of the battery right up till that point. I got 32.5 miles from the battery.
Battery number two is a 14s2p battery with about 55 cycles on it. I have not run this battery on my bike with a watt meter. Its been on my wife's bike.
Ultimate question is I would like to take a few rides with longer range and the possibility of charging some during the ride. Am I better off running these batteries separate or paralleling them. In my head the answers are gray. Maybe someone else can give a less biased opinion.
