Pinesal
Let me start by saying, I have a bike with SLA batteries. I bought a lifepo4 upgrade and had a bad experience and went back to SLA. After owning the lithium for 3 months, a hot day caused the BMS to fry and the battery became about useless. I couldn't figure out which BMS to replace it with and the ebay seller was no help so I just chucked a $400 battery in the garbage (recycled).
No I am not just making this post to badmouth lithium, I want to get away from SLA but it seems to have more pros then cons in my eyes. I am hoping some of you will be able to address my concerns and offer counter points. Well here goes.
1. Lithium is way more expensive. So even if you do save enough to buy one, you just got to pray it's not a lemon.
2. They are complicated, you have that extra part, the BMS, and all it's wiring, which is nearly required. So you can have bad cells, or bad BMS, or wires. Problems can be hard to track down.
3. Related to the last, lithium is usually made up of may cells which need to stay balanced. If one cell goes bad ,you gotta go through and test possibly hundreds of cells to find it. Then replace it and connect it back to the bms. With Lead you have just 3-6 cells.
4. It's hard to get an accurate power gauge. These batteries maintain their voltage until they are almost dead. There is almost no way to tell when the battery is, say, half empty.
5. They are hard to get. I have not been able to find any local stores that sell lifepo4 batteries without it being already part of a bike. I can buy SLAs anywhere, I even get a discount on them at a local shop.
6. I have heard that SLA can provide more amp power but I have not confirmed this.
SLA batteries are so simple, they are common, cheap and easy to just trip into your system. So they are heavy and lose power over time but at least they are reliable and don't fail easily.
